Craig_T Posted October 4, 2010 Posted October 4, 2010 Hello,What is the pedal travel like with the K Sport kit? Can the standard MC cope, or are they too big?Same for Willwoods and WMS kit if anyone knows.Thanks Quote
Keri-WMS Posted October 4, 2010 Posted October 4, 2010 I can't speak for the others, but we matched the piston area on the WMS calipers to the EP ones so there's only a 6.6% increase in area.This 6.6% plus the bigger discs plus the better pads (£ for £) is where the WMS kit gets it's increased power (braking torque at the hub per PSI in the fluid). The pedal should feel about the same, it's designed to work with the std master-cyl and you won't need to push the pedal hard anyway, trust me!Hope that helps! Quote
rorenapier Posted October 4, 2010 Posted October 4, 2010 Willwoods work just fine on the std master cylinder, no extra pedal travel and no soft pedal either. Quote
Craig_T Posted October 4, 2010 Author Posted October 4, 2010 Thanks ^^Anyone any ideas on K Sport? Quote
