DavidAshton Posted October 13, 2010 Posted October 13, 2010 ^^ A bit wrong imo?Of course it helps. Hole too small to expel enough exhaust gasses, make hole bigger, hole big enough to expel enough exhaust gasses, boost now creeps less.If your only just touching fuel cut it will cure your problem for sure. Quote
gtmuzz Posted October 13, 2010 Posted October 13, 2010 Porting the wastegate defonitly helps! That's all I had to do to keep mines of fuel cut and that's with a front mounted filter, gutted cat and straight through exhaust , there's no way I would pay anywer near 100 notes for it tho!!! £15's for some grinding stones and do it yourself not a hard job tbh Quote
Andrew Miller Posted October 13, 2010 Author Posted October 13, 2010 All you need to do it put the efi pipe back on.........it costs nothing (providing you still have it) and it solves the problem. Simples ? Quote
