JAG Posted October 14, 2010 Posted October 14, 2010 Ok so im after part numbers for ep91 window seals on both the driver and passenger front windows as my drivers is getting munched up by the window as i roll it up which keeps popping the front wind deflector clip off so ive had to remove that til i get it sorted...Then the passengers one drips a little.So thought i'd just replace both I had a look on that Toyo DIY site but i cant find the part number for the life of meAnyone happen to have replaced them in the past and have the part numbers?Cheers, JAG Quote
Rob H@RCH Engineering Posted December 23, 2010 Posted December 23, 2010 Ok so im after part numbers for ep91 window seals on both the driver and passenger front windows as my drivers is getting munched up by the window as i roll it up which keeps popping the front wind deflector clip off so ive had to remove that til i get it sorted...Then the passengers one drips a little.So thought i'd just replace both I had a look on that Toyo DIY site but i cant find the part number for the life of meAnyone happen to have replaced them in the past and have the part numbers?Cheers, JAGhttp://www.toyodiy.com/parts/p_E_1999_TOYO...NKW_6701.2.htmlthere you go there near the bottom of the page! Quote
