hybrid glanza Posted October 22, 2010 Posted October 22, 2010 i have a EP91 running jam ecu and hybrid set up. temp doesnt heat up past 30 degrees and oil doesnt heat up either help needed Quote
federalman Posted October 22, 2010 Posted October 22, 2010 How olds the thermostat mine wasn't quite as warm as it should, replaced the thermostat and it's fine now. Dave at tm developments does them Quote
WallaceGlanza Posted October 23, 2010 Posted October 23, 2010 Agreed, will most likely be the thermostat seal has perished or it's stuck open. Changing it is easy. Quote
BAZ2CRAZY Posted October 23, 2010 Posted October 23, 2010 Agreed, will most likely be the thermostat seal has perished or it's stuck open. Changing it is easy.As above. Thermostats' probably fuxxed. Not expensive and easy to replace.Mitch Quote
hybrid glanza Posted October 24, 2010 Author Posted October 24, 2010 changed thermostat and still doesnt heat up much better any ideas Quote
BAZ2CRAZY Posted November 19, 2010 Posted November 19, 2010 Sure your temp sender isnt fucked? So it appears as though it isnt heating up because your temp needle says so?Mitch Quote
