Oil burning and lots and lots and lots of smoke
hi guys, since changing my rocker cover, my car has been burning oil and smoking quite abit (as most of you guys at the manchester meet noticed :) ),
got home... checked oil and it below low... :D
topped it up...
I've been told its the PCV valve, so i swapped it with the one from my old rocker cover,
but still smoking and has it starts to pick up speed, it tarts to jerk abit!
could the smoke be just whatever oil is left trying to get out?
and why is the car jerking?
thanks
ishaq
I forgot to say, its pointless having that strut on when its not bolted in bolt it in or take it out lol
must be the PCV, as for the jerky thing have you tightend the pcv pipe properly could be unfiltered air getting in thats why its jerking
x2 could also be your burning oil via stem seals, drive it on low revs and see how she goes with regards to oil consumption as i/we noticed at the meet when you left you rev`d to pretty much the redline which doesnt help whatsoever........if it still does it change to heavier weight oil and start thinking of that conversion.
I've been meaning to bolt the strut in to make it 3 point..
the pcv pipe is tightend properly..
kept it to low revs and it dont smoke as much but has problem picking up sometimes...
will drive about with low revs and see how it goes...
working out conversion costs and doing research..
could there be oil in intake mani?
