Sparky Posted November 7, 2010 Posted November 7, 2010 Right guys will be doing a few bits to this engine I have picked up. Head will be coming off so will be needing a decent headgasket.I am swaying towards the Athena 1.4mm gasket but are they any good? Need to drop the compression a bit if I am going for 1.4 bar boost or would yopu recommend a 1.6mm?I also need to find the cheapest place for these bitsPiston Rings (any aftermarket ones available for stock pistons?)Timing belt kitOil pumpand I would need a gasket set I imagine.Thanks Lewis Quote
mk1kurt Posted November 7, 2010 Posted November 7, 2010 timing belt mate fensport is about the cheapest ive just got one from there but tm developments are just as cheap Quote
Sparky Posted November 7, 2010 Author Posted November 7, 2010 Cheers mate, looks like camskill is slightly cheaper for the timing belt kit than fensport but fensport are cheaper for the engine gasket set, oil pump etc. Gonna check a few other places now Quote
Dan507 Posted November 7, 2010 Posted November 7, 2010 oil pumps are for starlets are quite rare, you might have to go to toyota - it should come with the gaskets needed Quote
chris H Posted November 7, 2010 Posted November 7, 2010 oil pump from toyota is only £91.44 all in mate. Piston rings check out http://cgi.ebay.com/ebaymotors/ws/eBayISAP...RK%3AMEWAX%3AIT Hth,chris.Cheers mate, looks like camskill is slightly cheaper for the timing belt kit than fensport but fensport are cheaper for the engine gasket set, oil pump etc. Gonna check a few other places now Quote
chris H Posted November 7, 2010 Posted November 7, 2010 you don't get a gasket with the oil pump, toyota full gasket kit £139.75 from main dealer Quote
Dan507 Posted November 7, 2010 Posted November 7, 2010 Really? when we order them in at work there a complete set. Quote
chris H Posted November 7, 2010 Posted November 7, 2010 Lol, mr toyota must have robbed me of my gasket! all i got was the pump Quote
james@cjperformance Posted November 7, 2010 Posted November 7, 2010 any main dealer parts speak to gary at gbr dude, im sure he will get them a bit cheaper for you Quote
Craig_T Posted November 7, 2010 Posted November 7, 2010 You need to buy the o ring for the oil pump seperate... Quote
Socks Posted November 7, 2010 Posted November 7, 2010 get an athena headgasket sparky... they open up the extra waterways the stock ones block off (to aid warmup)come in i got a 1.2mm one! Quote
Sparky Posted November 8, 2010 Author Posted November 8, 2010 Cheers guys anymore recommendations on suppliers? Quote
whiteglanzav Posted November 8, 2010 Posted November 8, 2010 is it gunna be a forged engine dude ? what turbo are you going to be using - if its stock obv the pistons are gunna produce a higher cr so you would be better with a 1.4mm or if you are using forged low comp pistons then you will be better with a 1.2mmall depending on turbo/boost/pistonsedit: just seen your saying 1.4bar so is that gunna be on aforged engine then ?? Quote
sx_turbo Posted November 8, 2010 Posted November 8, 2010 for 1.4bar on stock internals go for the athena 1.9mm gasket, this should lower your compression to a nice limit.if going forged go for a 1.2 mm gasket, keeps response a bit better and compression is still quite low, wossner piston and 1.2mm gasket gives a cr of 7.84:1 which is quite low. Quote
Sparky Posted November 8, 2010 Author Posted November 8, 2010 Stock engine guys.I understand the thicker the head gasket the lower the compression and the more boost I can safely run but wont it also affect the way the car behaves off boost?? I dont wont it feeling undriveable off boost. Quote
whiteglanzav Posted November 8, 2010 Posted November 8, 2010 yer i know what you mean dude but i think you'd rather it be slightly boggy off boost than it spitting a rod through the block personally on a stock engine i would be wanting a thicker gasket as ricky says above go for the 1.9 or at least the 1.6off boost it wont really be that bad anyway + if your like me then youll be on boost most of the time so it wont matter - anyway all you have to do is change down a gear Quote
Sparky Posted November 8, 2010 Author Posted November 8, 2010 Cheers dude, doubt there is many people I can talk to who has done the same! Probably go for a 1.6mm then.And im sure it would be on boost quite alot lol Quote
