Guest cheshireglanza
maybe your breaks are sticking on small bit on left side making it pull to one side or you need your tracking doing
It could be a few things
1.Trackrod ends
2.Anti roll bar Drop links (check to see if they are bent orr the ball joint is fooked
3.Flat tyer lol ;)
I would put it down to Track rods go for the cheapest first
There was a slight knocking noise the day before lol ill do droplinks and track rod ends what uprated ones are there? thanks
  • 2 months later...
How did u get on mate ? Im having a similar issue.. think my track rod needs doing but be nice to hear what solved your problem.
Cheers
