Guest cheshireglanza Posted November 19, 2010 Share Posted November 19, 2010 got external wastegate with screamer pipe plum it from turbo to one off the ports on wastegate boost's all over the place,plum it in into other port it boosts at .3 bar only getting two green boost lights on dash holds back what can it be Quote Link to post Share on other sites
string Posted November 19, 2010 Share Posted November 19, 2010 boost hose goes from nipple on compressor housing to bottom port on wastgate. top port is left to vent. thats how its ran if ya using the wastegate spring pressure. wht spring do you have in? is the wastegate fully welded up? does ya ext w/g open at .3 and scream/ safe Quote Link to post Share on other sites
Guest cheshireglanza Posted November 19, 2010 Share Posted November 19, 2010 ^^ if i plum it in that way its boosts all over the place the other way it screames but thrid light on dash wont come on Quote Link to post Share on other sites
rorenapier Posted November 19, 2010 Share Posted November 19, 2010 What do you mean all over the place? Quote Link to post Share on other sites
Guest cheshireglanza Posted November 19, 2010 Share Posted November 19, 2010 its boosting well over bar lol only 5psi spring in wastegate Quote Link to post Share on other sites
lukEp Posted November 19, 2010 Share Posted November 19, 2010 You mean .5 bar spring mate Quote Link to post Share on other sites
Dean @RW-Developments Posted November 19, 2010 Share Posted November 19, 2010 i know exactly what you mean i did it with mine by fitting it to the top nipple it basically bypasses the e/w spring pressure allowing it to effectivly to boost how ever high it wants? on my car it was mental fast the only thing that was stopping it boosting crazy was the factory fuelcut. if you fit it to the bottom nipple and leave the top 1 venting to atmosphere it will run at spring pressure and at 5psi it wont be all that and the screamer will sound like its falling asleep lol a bit more boost and it will come to life and the screamer sound will completly changehope this helpsDean Quote Link to post Share on other sites
rorenapier Posted November 19, 2010 Share Posted November 19, 2010 Is the wastegate sticking shut?Are you sure you have a 0.5 bar spring in there? How many springs are fitted? Quote Link to post Share on other sites
Guest cheshireglanza Posted November 20, 2010 Share Posted November 20, 2010 1 spring cheers dean i took it garage tonight and he tested the wastegate its not holding pressure been sold fooked wastegate Quote Link to post Share on other sites
rorenapier Posted November 20, 2010 Share Posted November 20, 2010 Torn Diagphram. Quote Link to post Share on other sites
Guest cheshireglanza Posted November 20, 2010 Share Posted November 20, 2010 ^^ yes mate opened it up and there's holes in it Quote Link to post Share on other sites
