ali_legend Posted November 29, 2010 Posted November 29, 2010 Right guys i know that the starlets are 4x100 but ive herd 4x100 golf alloys wont fit.? :S which alloy fitment fits the starlets.? cheers Quote
Amjad Posted November 29, 2010 Posted November 29, 2010 4x100, LukeSR has some Golf alloys on his SR Quote
ali_legend Posted November 30, 2010 Author Posted November 30, 2010 so any 4x100 alloys will fit.? obviously 16" and below.? Quote
anup67 Posted November 30, 2010 Posted November 30, 2010 Yep my starlet alloys went straight on my 4 stud golf Quote
Lukew360 Posted November 30, 2010 Posted November 30, 2010 4x100 is four holes for the bolts, and there are 100mm between the bolts, so yes in theory 4x100 would fit.BUT. . . You also need to look at the offset of the wheel, because some will stick out way to far OR not enough so will rub on the inside of the arch.Hope this helps Quote
ali_legend Posted November 30, 2010 Author Posted November 30, 2010 what ofset you rekon is the best .? im in need of cheap alloys asap with good tyres,!?!?!?! Quote
starlet1.3si Posted November 30, 2010 Posted November 30, 2010 what ofset you rekon is the best .? im in need of cheap alloys asap with good tyres,!?!?!?! think standard offset for a starlet is ET38 Quote
