Tyron Devine Posted December 8, 2010 Posted December 8, 2010 Hi people as above im looking into buying a roll cage for my ep82 how much am i looking around ?? also has anybody ever made there own if so what metal is used ? thanks ty Quote
_shaun_ Posted December 8, 2010 Posted December 8, 2010 hey mate i was n look out for a cage for my ep91 so heres what i found. ;) dependant on how many points and if its a dash dodger or not u can get them from rhdjapan but postage will be a killer. i can give u the name of ebay merchant that can get the same cusco cages lil bit more expensive but miles cheaper than time u add postage from rhdjapan.however i spoke to killamats at zisco an he said he would make me a custom cage for my ep91 for a great price which i woulda took if i didnt buy 1 from cheshire. so well worth droping killamats a pm all depends on what cage your after and your price range. Quote
Tyron Devine Posted December 8, 2010 Author Posted December 8, 2010 Thanks alot pal im thinking of makeing 1 myself lol sounds stupid ino but if i get the right measurements of some one then its worth giving it ago lol what metal are the cages normally made from ? aluminium or a stronger metal ?? Quote
bullet513 Posted December 8, 2010 Posted December 8, 2010 www.bubbleandkick.com these guys build race cars, they are going to do my rollcage and perspec windows Quote
Tyron Devine Posted December 8, 2010 Author Posted December 8, 2010 www.bubbleandkickracing.com these guys build race cars, they are going to do my rollcage and perspec windowsThanks mate ;) Quote
Sparky Posted December 8, 2010 Posted December 8, 2010 Mine was £550 delivered second hand, 7 point dash dodger and fits a sunroof model GT which are hard to come by ;) Quote
bullet513 Posted December 8, 2010 Posted December 8, 2010 for what reason are you after a rollcage? if its for protection and not just for looks i would advise you dont get a dash dodger. Quote
Tyron Devine Posted December 8, 2010 Author Posted December 8, 2010 Im thinking of putting the gt on tracks as i cant get insured on her and i want a cage for both looks and safety lol ;) Quote
bullet513 Posted December 8, 2010 Posted December 8, 2010 The most obvious is the double bent A pillar bar that dodges the dash, in a roll over incident (the only circumstance where a cage of this design *might* help) this A pillar bar will fold up like a wet noodle. Even if it didn't, the small 'footer' plates that bolt to the very non-structural floor area would undoubtedly punch through the floor leaving you with no protection from the roof collapsing and crushing you.In addition the door bars are usually single bars located quite far inboard (close to you) offering very little in the way of resistance to a side impact and no additonal crush area before a foreign body hits YOUR body. In fact they're a lot more dangerous than the nice 'soft' curves of the door card and will probably break some bones.Additionally having a roll cage in a road car has a couple of serious downsides, the biggest being in any sort of accident you're much more likely to hit your head on the bars, potentially causing some serious injury. I hear you say "But race cars all have roll cages, they're much safer?" This is true, however in any race car driven in anger you're going to be wearing a helmet. Rollcage + helmet are designed to go together. Additionally being held into a conventional seat with a 3 point belt (e.g normal seat belt) you're free to move around a great deal in an energetic collision, once again making it much more likely you're going to hit your head or brake an arm/leg on the usually unprotected bolt in cage. "But my cage is covered with foam" Good plan, however it has to be the right sort of foam. There is an enormous difference between a pool noodle and proper roll cage padding. In comparison the roll cage padding is VERY hard. In anything other than a very low speed accident pool noodle or other type of fairly low density foam will offer minimal protection.Once again I hear you say "But I put a set of harnesses in my car when I installed the rollcage, I won't be able to move around enough to hit the cage" Unfortunately the majority of harnesses that I have seen installed on this forum are installed in a very dangerous way, usually the shoulder straps are mounted back to the original seatbelt anchorage locations which results in a steep downwards angle on the belts. In a serious collision this downward angle (assuming that they don't rip out of the floor and your seat mounts don't break) will place significant downwards force on your shoulders and can result in significant spinal injuries. I also often see people leaving out the 5th and (depending on the harness) the 6th belts. These are called the sub-marine belts and are designed to stop you slipping down and through the belts in a serious incident. Without them you are removing another critical feature of the safety system and you are likely worse than you were with the original 3 point belt, factory seat and airbag equipped steering wheel.Add to that the fact that virtually no serious motorsport governing body in the world (certainly none that I would race under) allow bolt in cages (without some fairly serious modifications at least) and for good reason. Bolt in cages are *much* weaker in every respect.coppied from fatmans post on tgtt Quote
