Alyn@swcc Posted January 4, 2007 Posted January 4, 2007 Help, me and muddyell are trying to find the gromit for the power cable of an amp to go through the firewall to no avail. anyone wanna help us? Quote
ecksjay Posted January 4, 2007 Posted January 4, 2007 the one i used for my boost gauge hosing was just behind the inlet manifold. Quote
Sparky Posted January 4, 2007 Posted January 4, 2007 Theres one in the passenger side behind the battery somewhere.... just gotta cut a littlehole in it and squeeze the power cable through.... pain in the ass to pull it down from the inside then though!!!!! Quote
Idrees Posted January 4, 2007 Posted January 4, 2007 Theres a black rubber bung thingy, pop a hole in that and get the wire through. Then either take the glovebox out and get the wire under the carpet, or squeeze your hand behind the glove box!Good luck Quote
Mart Posted January 5, 2007 Posted January 5, 2007 Use a big headed Screwdriver to peirce the black rubber, than cellotape the amp cable to it a push it through till it comes out the other side.. Quote
scutch0 Posted January 5, 2007 Posted January 5, 2007 i went thru the wheelarch on my n/a, theres a low grommet in there you can gain easy access to. Quote
muddyell Posted January 6, 2007 Posted January 6, 2007 I was originally goin through the wheel arch aswell because it was only wired up temporary and i had all the wires runnin through the carI thought it was about time i wired it all up properly and i now have everything neat and tidy Did this yesterday as i havent long had the car back from bodyshop so thought it would tidy everything up, once i get started on it i just wanna keep doin more and more but then i run out of money Nothin happenin to it now for at least 3 weeks Quote
