Scratchy Posted December 26, 2010 Posted December 26, 2010 ^^^as above dont know how to wire my boost guage up....it still work perfect just no lights hahaMY BOOST GUAGE Quote
ep91steve Posted December 26, 2010 Posted December 26, 2010 Red to red and black to black on cd wires if you get me Quote
Scratchy Posted December 26, 2010 Author Posted December 26, 2010 ep91steve said: Red to red and black to black on cd wires if you get mewire them into the wires running from the cd player...make a all round circuit??bit of a mong wi this stuff Quote
StarletMad Posted December 26, 2010 Posted December 26, 2010 Are CD players not yellow and red ??P.S. Disconnect the Battery Quote
Daniel. Posted December 27, 2010 Posted December 27, 2010 or wire it into the hazard light switch with scotch locks Quote
Raz Posted December 27, 2010 Posted December 27, 2010 I connected mine to my sidelights. Just run a bit of wire through the same hole you ran the vaccum line, connect it to the sidelights. Or CD player if you want it always live once the car is on.I'm sure if you connected it to the stereo it says on the wires what each one is so can't go wrong tbh. Quote
bucketep91 Posted December 27, 2010 Posted December 27, 2010 wire it to the rear fog light switch, thats the easiest and closest to your guage. Quote
shaneyb Posted December 27, 2010 Posted December 27, 2010 bucketep91 said: wire it to the rear fog light switch, thats the easiest and closest to your guage.Wouldn't it only light up when you put your rear fog on then? I need to wire up my boost gauge aswell. Quote
bucketep91 Posted December 27, 2010 Posted December 27, 2010 no mate it will light up as normal Quote
shaneyb Posted December 27, 2010 Posted December 27, 2010 I guess ill be looking to wire mine up to the fog then , cheers. Quote
Scratchy Posted December 27, 2010 Author Posted December 27, 2010 thanks for the helpdidnt see the posts today tho about the fog lightwent with the stereo and it worked a treat Quote
