brianffc Posted December 31, 2010 Posted December 31, 2010 looking a fitting a td04 apart from the de cat and manifold what else would a nd 2 change all ive done so far is fit a fmic de cat and manifold apart fae that ive no done anything else 2 the engine a no ill need 2 change the manfold and de cat again for the td04 1s but do a nd anything else thanks Quote
StarletMad Posted December 31, 2010 Posted December 31, 2010 Make sure you got TD04 actuator bracket as you have to turn the snailAlso oil + water lines Quote
_shaun_ Posted December 31, 2010 Posted December 31, 2010 id get a external wastegate tbh other than that its easy oil /water lines is just hooking pipes up i just did mine not hard at all Quote
Ryan-11 Posted December 31, 2010 Posted December 31, 2010 maybe a diffrent radiator (depends on what manifold u go for), air filter relocation kit if u dont want to mesh the turbo and some sort of engine management too Quote
iamlegend Posted December 31, 2010 Posted December 31, 2010 TDO4 turbo/wastegate welded shutmanifold with external wastegatedecatscreamer pipeexternal wastegate meshed turboall suited with the stock radiator walbra fuel pumpemb or emu aftermarket ECUoil and water linesFMIC either custom or a td04 suited pipingexactly what I am running in the end of january..... Quote
daz gt turbz Posted December 31, 2010 Posted December 31, 2010 ^^^couldnt have put it better myself! Quote
brianffc Posted January 1, 2011 Author Posted January 1, 2011 thanks for the info its helped a now no what ill nd 2 get 2 fit it Quote
Fro Posted January 1, 2011 Posted January 1, 2011 Bearing in mind you dont NEED to run an externally gated kit, but people tend to for better boost control when running higher boost. Quote
daz gt turbz Posted January 1, 2011 Posted January 1, 2011 uprated clutch is always a good move aswel Quote
Tom2 Posted January 1, 2011 Posted January 1, 2011 Hi there mate! you could do with a few things that are not said on these post My personal spec is:Race Tech TD04 kit, comes with everything apart from gaskets and bolts but they are easy sourced from Tm DevelopmentsFMIC ( Jperformance ones are ideal!! easy to modify to your TD04 )Gizzmo boost controllerWalbro fuel pump380 cc injectorsRRFPRTm Developments rocker cover and oil catch tank ( Advised for running a bar of boost or over)Cat back exhaustHKS VPRO ECU ( said to be the best ecu for a starlet but an emanage blue or ultimate would be fine )TRD leads ( magnicor will also be fine) New dizzy cap and rotor armThe items which are not completely necessary are:Rocker cover and catch tankInjectorsRRFPRLeads Rotor arm and Dizzy capBut these items will aid the rest of your setup!Hope this helps mate Cheers Tom Quote
