davidni Posted January 9, 2011 Posted January 9, 2011 Hello Folks.I have a 97 Starlet Sportif with 40,000 miles. My nearside pass/side drive shaft has popped out of the inner cv or tripod joint, it has tore the rubber boot and the shaft is now hanging down with the three tripod bearing on the end of the shaft still intact. The cv or tripod housing is still connected in to the transmission. Has anyone else had this problem? This car may have been involved in an accident before I got it. Could it be that the force of an accident has caused an issue that I was unaware of? I have also recently been driving in deep snow and icy conditions, could this have caused the problem? Does anyone know how to fix the shaft back in or will I need a mechanic? I have included a diagram to try and show the problem better.Uploaded with ImageShack.usAll help is appreciated. Thanks. Quote
Russleh Posted January 10, 2011 Posted January 10, 2011 pretty weird one that. i wouldnt think that the inside one could come out if its sitting properly in the hub because there will be no movement that way. Quote
davidni Posted January 12, 2011 Author Posted January 12, 2011 Thanks for your input. Just reposting to update in case anyone knows the problem now.I went to a mechanic and bought a Drive Shaft. I got it fitted and expected that to be it settled. On my way home the car was STILL making a weird noise everytime i was in a low gear revving it. It was okay when I was in fifth above 30mph, no abnormal noise at this point. Upon pulling out of a junction I heard and felt a bang from beneath the car. I pulled the car over to see that the new driveshaft has done the SAME THING! Wouldn't drive anywhere again of course.My father thinks that it is the GearBox Diff because he believes that is the end of the line? Anyone got any ideas? Thanks. Quote
Russleh Posted January 12, 2011 Posted January 12, 2011 it could be the gearbox but again if everything is fixed then there shouldnt be enough room for it to come out like that. i know im not being very helpful as i dont know but im sure that factory boxes with lsd require different driveshafts from ones without the factory lsd. someone correct me if im wrong. just a wild guess lol Quote
_shaun_ Posted January 12, 2011 Posted January 12, 2011 oem lsd boxes have 1 drive shaft longer than the other were as non lsd are the same size (i think if not its the other way around ha) Quote
Craig_N Posted January 12, 2011 Posted January 12, 2011 oem lsd boxes have 1 drive shaft longer than the other were as non lsd are the same size (i think if not its the other way around ha)I think the lsd boxes have the same size driveshafts. Quote
andy.i Posted January 12, 2011 Posted January 12, 2011 factory lsd boxes dont. lsd's put in a standard box doanyway its a sportif so i doubt it has an aftermarket lsd Quote
greasemonkeyspb Posted January 13, 2011 Posted January 13, 2011 this is a weird one that it keeps doing it maybe if the wheel bearing isnt quite right would cause slight movement in the driveshaft and could be pulling it out under turning out a junction and accellerating if you can imagine the wheel moving in and out this could pull out the driveshaft. or if the car has an accident could have caused suspension damage which alters the ways in which the driveshaft will move under hard accelleration and hard brakingjust a thought but a geometry check could determine suspension damage Quote
Steve GT Posted January 14, 2011 Posted January 14, 2011 argh driveshafts, utter pains lolmine popped out while i was doing 50 in my black GT. suprised i didnt do any damage to it apart from it ripped the drivers side wing/arch trim off lol Quote
greasemonkeyspb Posted January 14, 2011 Posted January 14, 2011 that is lucky at 50 lolthen again still makes you jump when it happens dont it hahai remember at work i was driving a 206 and the driveshaft collapsed on me but as it came out it jammed against something underneath i tell you something i stopped quick :D never did find out what caused it jus a freak accident!!!! Quote
