G9 ONK Posted January 12, 2011 Posted January 12, 2011 took my v out today as i aint been for a run in bout a month ive only been starting it on the drive.. i gave it a little bit on a straight road and in the higher revs seemed to be losing power only in 3rd 4th 5th gear anyone shed any light on this??? cheers guys Quote
G9 ONK Posted January 12, 2011 Author Posted January 12, 2011 checked them all seem to be in properly and not damaged at all... Quote
Sparky Posted January 12, 2011 Posted January 12, 2011 Standard ct9? Boost will drop off higher up the RPM range its normal Quote
Whitegv Posted January 12, 2011 Posted January 12, 2011 i had this on mine a bit back. it was when it was really cold outside. it was like it would boost, but not fully. if i let off and then booted it agian it would be fine. really weird feeling. its been fine since. make sure the airfilter isnt wet or full of shit Quote
G9 ONK Posted January 12, 2011 Author Posted January 12, 2011 its a hybrid ct9 and alright mate ill go out again and see if that works then ill check filter cheers Quote
Mike_trx Posted January 12, 2011 Posted January 12, 2011 If not, could be the clutch starting to let go, or a crack in the manifold caused this issue with me...would only show sometimes under the right conditions when the crack would really open up under boost Quote
