Well as you may well know i bourght a GT turbo spoiler. for my EP91 solida
now, although being a car geek, ive never done any bodywork stuff before. i should be fine spraying etc, but i need some instrctions on how to fix it to my car.
A couple people have suggested screwing it on, then bonding it on. thing is im not sure where to screw, presumably i need drill holes in the boot etc?
Cheers Tom
You'll have to screw it on for it to be secure. Drill 2 holes at the top of the bootlid and screw them in to the spoiler. Also use Stikkaflex on the inside of the spoiler so its nice and tight, but please DO NOT seal it with that (Meaning use it on visable areas) or else it'll turn into some nasty yellow colour after a few weeks, happens to the SR's front lip all the time!!
right, cheers idrees... but wont the spoiler crack? oh and its got two. bolts sticking down in the centre, presumably that used to fit into the GTs boot?
can i use the old GT thread? or is it easier to make new ones?
Cheers
Easy to use the old GT thread. What to do is, mark out where them threads go on the bootlid, and drill two right sized holes out.
Then use a bolt on the inside to tighten it up.
Make sure it a nice fit, then take it off, put Stikkaflex on all the inside, and fit it back on again.
Good luck.
well in that case yes it does, but i think i make need some of the previous fixings removed....other than that seems pretty straightforward
well easy to some1 that knows what ther doing...aka not me
Glad to hear you got it safe mate, Baz has one on his Glanza and also chall had one on his and i've seen a few others, it can definately be done mate, just sus it all out then attack it.
yea cheers delivered in top condition. yer ill have a look in the light...then spary it etc.
whos baz? is that the entire username? anyone know if he fitted it himself.
