Check the door switch it gets stuck over time. If you pull the rubber up and spray some WD in there might sort it, if not could be the box behind the clocks
the other thing you could try is get a curcuit tester or power probe, disconnect the lamp its self & jus check to see if ther is a power supply & a good earth goin to it, other than that im not sure what else you try
check that you are geting a 12v feed to the plug behind it if you are its probably the unit. you can test that with a continuity tester just to make sure (thats what mine turned out to be)
Marck
