OK heres my problem, i won a TD04 turbo on ebay last week, been waiting a while for it to turn up, turns out the guy had sent it to the wrong address, anyway, i picked it up from the post office today, opend the box when i got home and it turns out the guy has sent me a TD05 :p
my WEPR mani, down pipe and screamer allso arived today (thanks to rorenapier for them) obviously tese all match up to the turbo, what else will i need for the td05 turbo, is it the same as a td04 ????
allso, thee dosent seem to be anywhere for the water lines to go :lol: maybe i'm just being blind tho lol, any one got any pics of a td05 with all the water an oil lines on ???
any nfo would be great, cheers guys
water lines attatch via some threaded bolts. if u can find ya oil return. then opposite side is oil in. then one of the sides has two holes for water. td05 kits are same as td04. but on a stock 4e td04 would be better
theres 2 banjo nuts on there with metal pipes coming off, i'm guesing that they need replacing with the water lines rite ????
the fatter pipe is the oil return (turbo to sump ???) and there should then be 1 more for the oil feed ???
exactly the same turbo as that
http://www.google.co.uk/imgres?imgurl=http...=1t:429,r:6,s:0
If you dont have a forged engine i honestly wouldnt run the td05 mate, td04 would be a far better option as the td05 needs a fair bit of boost to make it worth running. Just a heads up before you go to the hassle of fitting it.
You dont need to run the water lines :lol:
The oil does all the cooling, but obviously after a long run or blat about, give the turbo time to cool down
TD04 and 05 bolt to the same manifold and downpipe.
The plan was to run a cheap td04 so i could sell my ct9 setup to get better injectors and a re map then get a TD04l, obviously this TD05 has turned up so i'll have to use that for now, i werent expecting to run mega boost till i've done the re map ect anyway.
what do i need to do if i'm not running any water lines, just find 2 bolts with the same thread to block the holes is it ?
Mine have been open for 3 years now, no issues here.
Debris cant get to the bearings, so everything is hunky dory.
ok no water lines it is then, any idea where i can get a oil fee andreturn, the only ones i've found are speed vision, any one know of any uk distributors ?????
Cheers for the info guys :(
You can get them from tm development mate it comes with water lines aswell if you did want to use then lol
