rabbit1234 Posted January 29, 2011 Posted January 29, 2011 [can any one help please?"]hi there every one. I've basiclly own my ep82 for 3 to 4 months now and when i first had the car it was running mint then about a month ago it developed somthing like an engine stutter or stall or somthing. basiclly whats happening is when accelerating hard 1st and 2nd gear are fine but 3rd 4th and 5th have this stutter all stall between 5 and 7 thousand rpm it fells like the engine is pauses for a split second and does it 2 or 3 times better 5 and 7 thousand, theres no drop in rpm or the boost gauge dosent drop. can any one help Quote
1987glanza Posted January 29, 2011 Posted January 29, 2011 first of all what mods has it got, jus makes it abit easier to pin point the problem Quote
Amjad Posted January 29, 2011 Posted January 29, 2011 Sounds like fuel cut, what is your setup? Quote
Stulet-GTT Posted January 29, 2011 Posted January 29, 2011 If its stuttering an staling between 5-7rpm then ya hitting fuel cut which is not good as it sound like your hitting it alot..I only use to take mine to about 5.5rpm any more an it would hit fuel cut, so try not to rev it so much as your will only in time blow it up... Quote
rabbit1234 Posted January 29, 2011 Author Posted January 29, 2011 I've got a decat, nur spec exhust and an uprated fuel pump.wot could i do to sort the problem out?thanks for the info you givin so far Quote
Amjad Posted January 29, 2011 Posted January 29, 2011 Do you have a boost gauge? If not get one fitted, if so what is the boost level?Fuel cut should only kick in at about 0.8bar so a boost gauge will tell you what's going on! Our cars tend to creep bast normal boost levels in the cold weather hence the fuel cut Quote
rabbit1234 Posted January 30, 2011 Author Posted January 30, 2011 but it was happening on warm days 2?to be honest mate that dont sound wright not being funny or anything.on the standerd boost gauge in the car when is problem happend the boost gauge dosent move nor the rev counterso does that narw down the problem? Quote
Stulet-GTT Posted January 30, 2011 Posted January 30, 2011 I've got a decat, nur spec exhust and an uprated fuel pump.wot could i do to sort the problem out?thanks for the info you givin so farAn uprated mani would help out aswell, Also a FMIC... Quote
