Do you mean 2 bolts (per wishbone) then on each side of the car? Allowing the wishbone to drop enough to fit the bar in.
Does it drop out easy then? and does the ARB not get in the way?
Edit: Scrap that. Just one bolt and it fits over the original mount and chassis (not inside) and then screwed back in??
The bar came with no washers? Does it need them?
there should be 1 bolt either side which you can undoo then fit inbetween.... i not fitted 1 but it should be piece of piss when you look underneath and align it up .
there should be a picture in my build thread of one mate
Found it yeah, cheers. But it seems like all the other images. They always stop short of showing the actual end piece all fitted... and i've looked at 10 or so....LOL
