I know a few of you have these wheels but where did you get them balanced? I've tried all the usual places but nobody has the adapter.
I'll travel anywhere around the northern section of the M25.
Thanks.
Take the but nut off the front and the full centre cap will fall to bits and fall out B)
Will try it myself now. The guy at the tyre shop said it doesn't come out. I will try with a persuader if it doesn't fall apart.
As above, there is a big nut holding on the centre cap. You need to undo that, it may require a lot of WD40 and maybe some heat but once that's off you can get them balanced as usual.
