JackStar Posted February 2, 2011 Share Posted February 2, 2011 I have a set of crower cams that i got to put in my fully blown 5e, but the plan has changed and im just going with 4e td04, so is there any point of putting the cams in a fairly standard 4e?The specs of the cams are pretty much the same as the 265 speedvision camsThe spec of the engine will be, dta standalone,wepr td04 kit, rebuild engine (standard spec), half core ally rad, 2.5" exhaust, apexi air filter, poss port+polish.Also if i do fit the cams, are the standard 4efte valve springs ok? im not looking to go past the standard rev limit.Thanks Jack Quote Link to post Share on other sites
Dan507 Posted February 2, 2011 Share Posted February 2, 2011 I'd put put them in. IMO Cams are one of the best mods to can do to on any engine. Quote Link to post Share on other sites
shorty Posted February 2, 2011 Share Posted February 2, 2011 I run speedvision cams dude and tbh it depends what you want from the car, when they kick in they are awsome but off boost the car is lazy and before 3.5-4k they make no major difference. That spec is for higher rpm, so if your gonna run 1bar or less dont bother tbh, saying that they will give alot more pull when you get up the revs, wich is where the td04 pulls well anyway so in conclusion its completly your choice, only you know what you want from the car driving wise. Quote Link to post Share on other sites
Guest Enzo Posted February 2, 2011 Share Posted February 2, 2011 id defo stick them in, the right cams will make a tdo4 touch 300bhp fly powerand the stock springs should be ok if your on the stock revlimit, if your geeky with the toyota epc, 4ag/yars valvesprings fit, which are good for 8.5k Quote Link to post Share on other sites
JackStar Posted February 2, 2011 Author Share Posted February 2, 2011 well, i wont be going for 300bhp lol, will only have stock internals, but i will fit them if they make a good difference, just means ive got the task of shimming them Where can i get shims from if i need them? toyota?Jack Quote Link to post Share on other sites
shorty Posted February 2, 2011 Share Posted February 2, 2011 Yea toyota bud, ill upload the part numbers for all the shims later when im on the laptop, if i forget though just pm me if/when you want them Quote Link to post Share on other sites
Russleh Posted February 2, 2011 Share Posted February 2, 2011 id go for it ;) one thing i need to read up on is cams lol Quote Link to post Share on other sites
