Liam_D Posted February 6, 2011 Posted February 6, 2011 Anyone fitted Reflet rear units to a 96 Spec Glanza V before? Went to fit mine today and the lights are totally wrong, like reverse lights instead of fogs, White indicators etc... What looms do you use? as i have a 96 Spec Glanza loom, and a N/a loom and a pair of looms i got with the Reflet units and none of them seem to work. Best one is the looms supplied with the Reflets everything works and lights up fine apart from the rear fog? As my rear fog is the bottom light part of the lights on both sides? Any suggestions guys? As i would really like to get these fitted ASAP.Thanks in advanceLiam Quote
Amjad Posted February 6, 2011 Posted February 6, 2011 Why not keep your Glanza loom? My 98 specs fitted into my NA loom and I modified it to light up like a Glanza? Quote
Sparky Posted February 6, 2011 Posted February 6, 2011 Yea mate they should work fine, the looms dont differ or shouldnt do.You just need to change the bulbs because obviously the 96 spec use clear bulbs where as the reflets use coloured bulbs because the lenses where they shine through are clear. Quote
Liam_D Posted February 6, 2011 Author Posted February 6, 2011 Glanza loom dosent work, side lights light up white and the indicators are also white, swapped bulbs over and its still the same! Quote
Sparky Posted February 6, 2011 Posted February 6, 2011 Mate stop being so thick and get some coloured bulbs, jeez Quote
Liam_D Posted February 7, 2011 Author Posted February 7, 2011 Sorted it today guys, had to rewire in a wire for the rear lights! Shame they dont light up JDM style anymore. Quote
