Taggy Posted February 9, 2011 Posted February 9, 2011 I have bought a TD04 Turbo and the advert said it was 5g, is this normal for a td04? what G is a ct9? Quote
kirky1 Posted February 9, 2011 Posted February 9, 2011 5 is the cell number and g is the block which the prisoner made it in Quote
nazzurro19 Posted February 9, 2011 Posted February 9, 2011 i thought it stood for gram so like a td04 16gram Quote
LukeSR Posted February 9, 2011 Posted February 9, 2011 5 is the cell number and g is the block which the prisoner made it in Quote
Driver Posted February 9, 2011 Posted February 9, 2011 'G'ay?'G'andalf (as in the wizard)The higher the number before the G the more powerful the 'Wizard' (turbo)Like runescape Quote
Guest Enzo Posted February 9, 2011 Posted February 9, 2011 I have bought a TD04 Turbo and the advert said it was 5g, is this normal for a td04? what G is a ct9?there are 141 different versions of tdo4 turbothe g part denots the compressor wheel used. you also get L, HL H, HR, T and B corresponding to housingsheres a link to some of those turbos http://www.turbomaster.info/eng/catalogs/m...amp;pagina=TDO4a tdo4 11B would be closer to a ct9a/b a tf035 is probably the best suited to the 4efte - its found on the mk1 forester turbo Quote
