hello just bought a starlet gt turbo it has straight through exhaust system including de cat and exhaust manifold plus front mount intercooler plus cone filter also a boost controller.I would like to get around 170-190bhp wat would u guys recommend me to do ?
i understand when u start fitting exhaust and front mount intercoolers it alters the afr which is the best device to change this i was looking at a hks afr which is around £100 i dont really want 2 be spending £300 plus on emanage for the time may in the future. i understand aswell with the boost controller i can change my boost i read on here i think that the standard ct9 turbo can take 1 bar boost all day long, then oviously i guess i need to up the fuel pressure so would have to get a fuel pressure regulator and 255 fuel pump. ive bought a hks fcd aswell ive read alsorts or things about the fcd so not that sure on it im guessing from wat ive read if u put a fcd on you must check the afr or u will f**k your engine.
as much help would be greatfull
cheers mark-tozer
What actuator you running?? an yes you can run @1bar on the actuator but check the afr's
im still running standard actuator so i presume would i have to upgrade to a hks one
Here is my spec list and im running an estimated 185-190bhp, however mine is done all the proper way with no money spared..
Greddy E-Manage Ultimate ECU all mapped properly by reputable tuner
Standard CT9 turbo mapped to run at 1 BAR pressure
HKS adjustable Actuator set at 1 bar
Autobahn88 Decat pipe
JPerformance Stainless steel unrestricted manifold
JPerformace 2.5" Stainless steel catback exhaust (not very loud, nice and subtle!)
Jperformance Huge Front mount intercooler
TOY tuning air filter relocation kit (moves intake to front bumper)
MAgnercor 7.5 Red competition leads!
Higher heat range spark plugs
Cusco oil catch can (not fitted yet)
SPEC 6 paddle Track and street clucth (brand new)
However you can also reach it using a fuel pressure reg, upgraded actuator (hks), fuel pump, you may also need a better intercool but dont hold me to that :thumbsup:
Dan.
bump
Ya mate you wood have to get a hks actuator if it was me take out the a/c that will give you more brake better ht leads, spark plugs. But ya make sure you get a fcd and a fpr and get it rolling road to get it set up rite
ok thanks thats very helpfull i presume when you have a emanage you oviously get it mapped
so you dont need fuel pressure regulator , air and fuel adjuster and fcd
Yes that is correct however you could always opt for an aftermarket ECU in the likes of Blitz, JAM, Zep and others, thes ECUS apparently are self learning up to 200bhp and are easy good enough for the setup your after and can usually be baught for the £500 mark!
Dan.
You will need engine management for those figures, either e mange or plug an play ecu all depends on which one you want and how far you hope to go
so its not possible with fcd some sort of fuel and air ratio adjuster fuel pressure regulator and fuel pump
ok thanks may think of buying an ecu then
Dan.
Saw 2 x cars make 200bhp at lasts years rr day on plug an play :thumbsup:, rather than spend money on the parts an time spent getting it set up invest in plug an play :D but if you are then wanting to hunt more power then e manage
John
John
Wish i had of gotten an access or something instaed of the emanage ultimate :D I dont need more than 200 bhp just yet!
Think anyone would wanna swap and emanage for an access?
:D
Dan.
:D
Dan.
^^^ Exactly why i went Access :D happy with my motor an the Blitz ecu :thumbsup:
when u say plug and play is this a piggyback ecu u plug in to standard wats the best make etc..
Yes they are a straight replacement for your ecu that has been piggy backed, any of the Blitz,Jam,Mines units
They remove fuel cut, raise rev limit etc do a search loads of info on here
John
