Every time i hit a massive bump, a massive BANG happens, coming from the front,
ive had a look, and i think its due to there being no rubber bump stop being fitted to the top of the damper strut
should there be rubber bump stops fitted on standard shocks?
also are those springs standard?
There should be a bump stop
You have RSR springs a jap make lower around the 25-30mm mark iirc
The metal "shaft" of the shock looks quiet thick too compared to standard so id assume you have uprated shocks? do you have better pics?
FCK me! ive just noticed wheres the bottom perch for the spring? :lol:
