oli_h Posted January 21, 2007 Posted January 21, 2007 else have problems getting their car into gear some times, it ent me being stupid, i men i properly have to fight to get it in, its like theres a wall in the way and it wont go in its happend a few times now just wondered if any ones elses is like this as its like the linkages are well out or some thing Quote
lobotomy Posted January 21, 2007 Posted January 21, 2007 Never had a problem with mine -- I've crunched 2nd a few times and ended up looking stupid, but that's because of the stupidly long throw on the standard gear change.Could be linkages mate, I'm not a big gearbox guru but could it be the synchro mesh? Quote
miracle411 Posted January 21, 2007 Posted January 21, 2007 I had a little bit of a similar problem in my old ep91, i used dropped the clutch down again then put it into gear, this only happened in 1st or reverse though, which happens in most cars i think. Quote
Idrees Posted January 21, 2007 Posted January 21, 2007 Happens to the SR quite often. And it makes a gay noise when you put it in second whilst giving it some. Quote
starletno1fan Posted January 21, 2007 Posted January 21, 2007 yeh mine crunches into 2nd wen i give it sum aswell. bad Quote
Mikey Jay Posted January 21, 2007 Posted January 21, 2007 Mine cruches into 3rd every now and then but is me lifting off the clutch too early Usually complains when putting it into reverse though Quote
Sparky Posted January 21, 2007 Posted January 21, 2007 yea common fault on starlets, crunchin itno second when giving it some mine does it Quote
Jozinobi Posted January 21, 2007 Posted January 21, 2007 Solution = TRD Quickshifter & Bearing Upgrade Kit - ala Keiichi Tsuchiya Stylee!!!Joz Quote
Sparky Posted January 22, 2007 Posted January 22, 2007 i heard about changing the bearings...where can i get some from Joz my man??? Quote
oli_h Posted January 22, 2007 Author Posted January 22, 2007 its a pain to get in to second in high revs because i mentioned it to rich he said common but this is happening after ive been driving around for atleast 20 mins, its like the lever is stuck in a rectangle because il go to put it in the gears but its just a wall if you can understand my shite way of understanding and then i have to force it to get in to it which why it makes me think that the linkages might be fooked or some thing like lobo i dont know much really but i know it shouldnt be doing that Quote
ecksjay Posted January 22, 2007 Posted January 22, 2007 yeah moving that little block round helps infinately from what i heard.quickshift dont make much difference - just makes the throw shorter. Quote
*Toymota* Posted January 22, 2007 Posted January 22, 2007 my sr used to be a pain to get into 2nd gear at times! my glanza has a paddle clutch and quickshift and is occasionally difficult to get into 3rd Quote
oli_h Posted January 22, 2007 Author Posted January 22, 2007 ye it baffles me as i went to go see rich and he mentioned it he had a look but all is fine maybe its just one of those things Quote
