yaristurbo Posted February 17, 2011 Posted February 17, 2011 http://cgi.ebay.co.uk/Delphi-Rochester-880...=item1e61a51076as above guys Quote
GAZ@A&G_TUNING Posted February 17, 2011 Posted February 17, 2011 bit big mate ain they 880's on a starlet be a pig on idle lol Quote
yaristurbo Posted February 17, 2011 Author Posted February 17, 2011 i will be able to take fuel out the map at idle with having the motec, its good for that lol, will they fit in size Quote
Glanza_cl Posted February 17, 2011 Posted February 17, 2011 there to big mate, i wouldn't bother. Quote
yaristurbo Posted February 17, 2011 Author Posted February 17, 2011 what car can i get some out of some mentioned some supra ones not long back??? Quote
rorenapier Posted February 17, 2011 Posted February 17, 2011 Regardless off Motec or not it will be an absolute pig at idle, and part throttle driving. RX7 550cc drop in and work, as long as there high impedance. Even still 550 are over kill on most setups. Quote
yaristurbo Posted February 17, 2011 Author Posted February 17, 2011 Will the rx7 ones be good on a 5e Quote
GAZ@A&G_TUNING Posted February 17, 2011 Posted February 17, 2011 what rory say's, 550's on a 5e you will have to be going some to max them out, gotta remember were only 1.3-1.5 engine's not feeding 2lt's!!!! Quote
yaristurbo Posted February 17, 2011 Author Posted February 17, 2011 <br />what rory say's, 550's on a 5e you will have to be going some to max them out, gotta remember were only 1.3-1.5 engine's not feeding 2lt's!!!!<br /><br /><br /><br />Right, so 550cc or below then, seen some on speedvision ??Hmmmmmm... Pp bluepaint lol Quote
Glanza_cl Posted February 17, 2011 Posted February 17, 2011 Speedvision have a wide range of tried and tested injectors that work on the starlets... i run 550's in my Subaru and am pushing over 350bhp and still not close to maxing the injector duty out. Quote
starlet666 Posted February 17, 2011 Posted February 17, 2011 i have an emanage that is capable of running 1000cc rochesters, but the fuel that they consume burns alot quicker than pump gas....if u were running E85 or a blend, you will defz need 550cc or more.....i personally blend my own race gas, i call it MD60 it has pretty much the same properties as e85, but can add a bit more timing and it will loose power before it detonates take 40 litres of 98RON premium unleaded gas, and 60 litres of methanol, mix it in a big drum, and pump it out into 20 litre drums and make sure it is airtight, as methanol absorbs water and the gas goes offi have found this blend to be slightly better than e85, but it is just as bad on fuel lines, and as such, i cant be held responsible for what happens if your car isnt made to run it, but it does work....i ran my 500hp s15 silvia on it and from 500 on pump gas it was able to make a touch under 600 safely, my 750hp aristo got it for track time only and the starlet gets it sometimes too, but being on an emanage i have to change the injectors back to 550cc to make it drive on pump gas Quote
yaristurbo Posted February 17, 2011 Author Posted February 17, 2011 it will be run on Vpower can remember the ron is it 98ron. Quote
