Whitegv Posted February 22, 2011 Share Posted February 22, 2011 i changed my engine this weekend and have swapped everything over from the old one. spotted a leak this morning.its coming from the what i can only describe as the engine side of the thermostat housing, the bit where the turbo water lines and top rad hose connect to, its leaking between that and the engine head. the small black gasket type thing is there, and looks ok, should there be another gasket or is it just this one?where can i get a new one?for the time being i have used some of that instand gasket stuff as i need the car. Quote Link to post Share on other sites
BigMan Posted February 22, 2011 Share Posted February 22, 2011 drop enzo a pm, he should be able to get a gasket for that for you Quote Link to post Share on other sites
TrisK Posted February 22, 2011 Share Posted February 22, 2011 drop enzo a pm, he should be able to get a gasket for that for youthats the only gasket i can see round there.16325-63011 - Water Inlet Housing GasketHope thats some use mate Quote Link to post Share on other sites
Whitegv Posted February 22, 2011 Author Share Posted February 22, 2011 sound thanks lads, ill have a word with him ta Quote Link to post Share on other sites
Dave@TM-Developments.com Posted February 22, 2011 Share Posted February 22, 2011 It doesn't use a gasket, use good quality sealant Quote Link to post Share on other sites
Whitegv Posted February 22, 2011 Author Share Posted February 22, 2011 even better, thanks dave Quote Link to post Share on other sites
