alright, i have 1 yellow wire which is meant for the indicators to flash wen locked/unlocked.
I have split the wire at the end so there are 2 lengths and then wired each 1 to the indicators behind the hazard switch. I've tried the rest of the bits behind the hazard and they are just exterior, interior lights and and 1 of them always shorts my fuse out!
But the problem is, when i indicate, its basically my hazards as both indicators come on!
So, can anyone tell me what to do to crrect it?
im not sure i follow bud.
can you explain in some more detail?
what kit are you using? what has already been wired up? and what does the wiring diagram say?
ive fitted 3 alarm systems and they've all had totally different wiring to make the hazards flash... it'll be helpful to know what your instructions say.
Rich.
