rob_bower Posted August 3, 2014 Posted August 3, 2014 Iirc correctly one of the wires is the remote switch for the starter motor. I just chopped the plug off and wired them together. Quote
turbomad Posted August 5, 2014 Posted August 5, 2014 This sensor by the brake servo can be removed And the plug that connects to it can be cut back and joined togetherStill yet to do this Also this plug can be cut back as it's no longer in useAlso this is what I did to vent the fuel line Quote
turbomad Posted August 9, 2014 Posted August 9, 2014 (edited) New pics of my silicone blanking nipples Edited August 9, 2014 by turbomad Quote
mech5107 Posted August 9, 2014 Posted August 9, 2014 The one by the brake booster should be for the charcoal canister vent. You remove this and the canister, plug the line going to the intake, put the line from the gas tank to a breather or with a small inline filter to a hole in the chassis rail. That's what carb cars do.The other valves the one with the cylindrical thing on it is for the air con. Idle up valve...All those valves that one line is going before the throttle body and one after, can be removed, but the idle would fluctuate when the related accessories are operated. Quote
