GlanzaJim Posted March 14, 2011 Posted March 14, 2011 are they the same? or what ever if bigger i wana put in my n/a? cheers Quote
Jozinobi Posted March 14, 2011 Posted March 14, 2011 Starlet n/a and UK Paseo injectors are both 195cc buddy.The 5EFHE ones are 225cc, 4EFTE is 295cc.If you are not close to maxing out the current injectors then there is no real need to upgrade as you don't want to overfuel/flood the engine.Don't be fooled into thinking just adding bigger injectors alone will add more power, especially as there is no additional air coming from anywhere.Joz Quote
GlanzaJim Posted March 14, 2011 Author Posted March 14, 2011 Starlet n/a and UK Paseo injectors are both 195cc buddy.The 5EFHE ones are 225cc, 4EFTE is 295cc.If you are not close to maxing out the current injectors then there is no real need to upgrade as you don't want to overfuel/flood the engine.Don't be fooled into thinking just adding bigger injectors alone will add more power, especially as there is no additional air coming from anywhere.Jozaww okay thanks for that info, just really wanted bit more fuel going through thats all. thanks joz. Quote
Mo3 Posted July 1, 2011 Posted July 1, 2011 ye mang if tis N/A you really dont need more fuel coming in.. Quote
