Right fitted new civic rad, turbo kit, air filter relocation kit and braided oil feed pipe.. To realise that my oil return pipe is no fitting on to the turbo ( the bit that comes from the sump)
Has any one else had this problem? What did you's do to resolve problem
If it came as a kit it should fit!
If not find the O/D of the sump and turbo return pipe and buy a 90 degree bend hose to fit.
http://cgi.ebay.co.uk/25mm-1-SILICONE-ELBO...=item43a1309f7a
Something like the above to suit the O/D size you need :ph34r:
IIRC u cant use these for the oil drop off as the oil will degrade the pipe causeing it to split then u are in trouble think it has to be a pipe made for oil
