dannyhack Posted March 18, 2011 Posted March 18, 2011 Whenever i go over bumps, sounds alot like the rear window is shaking or banging against something, any ideas what it could be?Thanks Quote
nazzurro19 Posted March 18, 2011 Posted March 18, 2011 just starlets for ya, mine rattles n creaks with all the struts etc ive got fully strip ftw then nothingcan rattle lol Quote
dannyhack Posted March 18, 2011 Author Posted March 18, 2011 it's just so annyoying lol, no way to stop it?Thanks Quote
nazzurro19 Posted March 18, 2011 Posted March 18, 2011 you could try putting something inbetween the rattle like a sock or cloth to see if it stops then if it does buy some sound dedning material Quote
bucketep91 Posted March 18, 2011 Posted March 18, 2011 used to get an anoying squeeky rattle from the back of mine, it was the little rubber stoppers on the parcel shelf rubbing on the rear window, jammed a little bit of rubber into them and it stopped Quote
Chopster Posted April 15, 2011 Posted April 15, 2011 used to get an anoying squeeky rattle from the back of mine, it was the little rubber stoppers on the parcel shelf rubbing on the rear window, jammed a little bit of rubber into them and it stoppedI used to have a similar problem, thanks to your qoute I'm now quite sane! Quote
