siren676 Posted March 24, 2011 Posted March 24, 2011 Im going to be doing a front brake upgrade soon and have found a gt brake setup and want to know if they will fit.I know that the abs is detected from the cv joint so im hoping the setup will just be a straight swap.Anyone know anything about this? Quote
Keri-WMS Posted March 24, 2011 Posted March 24, 2011 As far as I know all the calipers are the same format/fit.... you just need to match them to the right discs. Quote
ryan lang Posted March 24, 2011 Posted March 24, 2011 i read that the 98 spec glanza had slighty bigger front callipers, but not sure if this is true?? Quote
siren676 Posted March 28, 2011 Author Posted March 28, 2011 I checked toyodiy and it seems that gt's, glanza's and paseo's all have the same calipers (even the 98 spec glanza).Ill be picking up the setup this week and will report back whether it works or not.Cant wait to get rid of the pitiful 238mm disks Quote
siren676 Posted March 30, 2011 Author Posted March 30, 2011 Picked up the brakes today and some of the bolts were seized and the pads were the wrong size so im taking them back tomorrow and exchanging them for another set.I compared them to my current brakes and the only difference that I could see was that the pad holders were about 5-7mm taller to be able to take the bigger disk. Quote
