hi there, have just had my lowering springs delivered........ front springs are fooking huge compared to mine!!!! probably 15 - 20mm wider diameter wise, does the glanza have wider front springs? if yes there will be a brand new set of springs for sale imediately!!! FAIL!!!
do they just look different in size because they are progressively wound? have you had both springs next to each other to compare?
ive measured them both across the diameter's and the new springs are huge!! they look like they have come off a lorry or something!!! lol
i'll put a picture up later!!! lol, the spring diameter is much larger than the cup they will sit in!!
