Mr2_Badboi Posted March 27, 2011 Posted March 27, 2011 hi there,i have a starlet turbo,which i bought to run around in and now i have sold it to a friend..problem i have is,the car was fully stripped out,i put all the dash in and etc,so when my friend came to pick the car up,it starts then cuts out after 3 seconds or so,so i kept the key turned and it kept running and was ok, but now i think the starter has burnt out as its not doing anything,but the car was totally fine before has been stood still for around a month or so any ideas will be very gratefulli have cleaned the dizzy cap and leads there all fine please someone help me Quote
Mr2_Badboi Posted April 25, 2011 Author Posted April 25, 2011 hi can someone please help me,the ep82 which i have is still not running!!,and the guy who i have sold it too,is now got some people after me as i carnt get his car running,i wish i never took this job on,i sold the car was fully stripped out,then i put a full interior in it,and it was stood still for a while...then he came to pick the car up and started it,it starts then cuts out after 3secs?????,so then i kept the key on start it kept running???....and now it does nothing apart from a clicking sound from the passenger side dash,is it fuelling,starter,coil what could this be as am really struggling???so all help would be helpfull Quote
GT Phayer Posted April 25, 2011 Posted April 25, 2011 battery ?might be a burnt out starter motor if the battery is ok and its been cranked over loads Quote
Mr2_Badboi Posted April 25, 2011 Author Posted April 25, 2011 battery ?its not the battery mate,as i had it on a mains starter/charger,someone told me it could be a kingpin lead?? Quote
GT Phayer Posted April 25, 2011 Posted April 25, 2011 so as soon as u go to start it it just clicks ? Quote
bucketep91 Posted April 25, 2011 Posted April 25, 2011 if its starting then cutting out its not the starter. when it is running what is it idling at? Quote
Mr2_Badboi Posted April 25, 2011 Author Posted April 25, 2011 so as soon as u go to start it it just clicks ?/right you know when you turn your key to start a car then you let go when its started??,the car used to run for 3 secs then cut out??,but if you kept the key on start it ran,but with doing this the starter was on load and glowing,but now the car will not turn over at all,but what i want to know it why would it run for only 3sec's then cut out has this never happened to anyone before?? Quote
bucketep91 Posted April 25, 2011 Posted April 25, 2011 so youve burnt the starter out? id try replacing that first of all then start again Quote
Mr2_Badboi Posted April 25, 2011 Author Posted April 25, 2011 so youve burnt the starter out? id try replacing that first of all then start againyes the starter may poss be burnt,but its the running and cutting out bit want i want to resolve??,just want an idea what it could be,is it common??,has it happened to someone before,the car has been stood for 6 months id say Quote
bucketep91 Posted April 25, 2011 Posted April 25, 2011 could be anything really mate, have you done a diagnostics check? Quote
GT Phayer Posted April 25, 2011 Posted April 25, 2011 would stail fuel cause this ? might help putting some clean new fuel in mate Quote
nazzurro19 Posted April 25, 2011 Posted April 25, 2011 check the king lead by touching it on ya rocker cover and turning the car over if it sparks then its okthe clicking i wouldnt say is the starter motor , id say battery too cause when my car was left for a while i tried turning it over the car then started to whir slower n slower then it made a really loud clicking noise and i mean really loud, recharged the battery , car started instantlyonly other thing id check is all the spark plugs etc they might have flooded with the amount of turning over ya done , try giving em a clean etc Quote
Mr2_Badboi Posted April 25, 2011 Author Posted April 25, 2011 would stail fuel cause this ? might help putting some clean new fuel in matei havent done a diagnostics check?,is that a paperclip one??,where is the port?thanks for that mate fuel has been put in so that is out of the question Quote
Mr2_Badboi Posted April 25, 2011 Author Posted April 25, 2011 thanks for the reply mate,yes i have spark on all plugs??!!,thats what i carnt understand,its absolutely racking my brains out,and getting me into trouble now Quote
nazzurro19 Posted April 25, 2011 Posted April 25, 2011 fuel pump maybe ? is there a whining noise like its priming when turning the car on ?also check all ya fuses and relays ? specifically the EFI fuse Quote
Mr2_Badboi Posted April 25, 2011 Author Posted April 25, 2011 fuel pump maybe ? is there a whining noise like its priming when turning the car on ?also check all ya fuses and relays ? specifically the EFI fusei have checked all the fuses and they seem fine,inside car and engine bay,but how do i check relays??,EFI Fuse where is that located?? Quote
Mr2_Badboi Posted April 25, 2011 Author Posted April 25, 2011 i have checked all the fuses and they seem fine,inside car and engine bay,but how do i check relays??,EFI Fuse where is that located??fuel pump is ok,as it was starting for 3secs then cutting out,and that is the longest time it would run, Quote
nazzurro19 Posted April 25, 2011 Posted April 25, 2011 check continuity on a multimeter for fuses and as for location no idea but use the search on here and ull see it Quote
daz gt turbz Posted April 25, 2011 Posted April 25, 2011 make sure the ingnitor has a good earth, mine had some of these symptons and turned out the earth points on the ignitor had corroded, so cleaned them up and made a little earthing strap to the bulk head which sorted the problem! Quote
Mr2_Badboi Posted April 25, 2011 Author Posted April 25, 2011 make sure the ingnitor has a good earth, mine had some of these symptons and turned out the earth points on the ignitor had corroded, so cleaned them up and made a little earthing strap to the bulk head which sorted the problem! ok mate il try that,does anyone have a kingpin lead,starter motor,for sale?? Quote
