200bhp starlet Posted March 30, 2011 Posted March 30, 2011 as above if so was it hard or what ???? thanks lewis Quote
nazzurro19 Posted March 30, 2011 Posted March 30, 2011 what i normally do is get a extension for a ratchet and the correct socket to fit then use elecy tape if its still a bit loose home made tools ftw , by the way ive done my polo and my mates scooby twice with his method Quote
micky boy Posted March 30, 2011 Posted March 30, 2011 As said above mate use an extension for a ratchet and you should be fine Quote
200bhp starlet Posted March 30, 2011 Author Posted March 30, 2011 ok thanks guys dont really wanna shell out on a tool to use once lol never done a clutch before so hope it all goes smooth Quote
micky boy Posted March 30, 2011 Posted March 30, 2011 No problem mate if you get stook on something im sure we will be able to help im sure theres a guide on how to change a cluch on here somewhere? Quote
200bhp starlet Posted March 30, 2011 Author Posted March 30, 2011 No problem mate if you get stook on something im sure we will be able to help im sure theres a guide on how to change a cluch on here somewhere?thanks mickey your a legend i will try find the guide now also is it just a standard gearbox oil or do you recommend a better one i was just gonna grab some from toyota with the oil seal for where the driveshaft goes in the box Quote
dac69er Posted March 30, 2011 Posted March 30, 2011 i have done the same. socket set extension. as i have 4 starlets i thought i would invest in the proper tool dont cost much Quote
200bhp starlet Posted March 30, 2011 Author Posted March 30, 2011 i have done the same. socket set extension. as i have 4 starlets i thought i would invest in the proper tool dont cost muchif the extension works then no need lol Quote
micky boy Posted March 30, 2011 Posted March 30, 2011 thanks mickey your a legend i will try find the guide now also is it just a standard gearbox oil or do you recommend a better one i was just gonna grab some from toyota with the oil seal for where the driveshaft goes in the boxHmm not to sure on oil to be honest its a non LSD box so i can see it needing anything special.. Quote
Russleh Posted March 30, 2011 Posted March 30, 2011 with most of the tools its just as easy to put it in squint as it is usin your eye I've found. Quote
200bhp starlet Posted March 30, 2011 Author Posted March 30, 2011 Just use your eye Hold the friction plate centre as you nip up 2 opposite bolts and it's good to go.ok thanks matey just to clarify will toyota gearbox oil do the job ???? Quote
200bhp starlet Posted March 30, 2011 Author Posted March 30, 2011 ANY 75w90 oil will do You'll need 2 liters of it.your a star mate cheers roll on sat now lol Quote
200bhp starlet Posted April 12, 2011 Author Posted April 12, 2011 Have you started doing the cluch yet?sorry for late reply mate yeah all done but now get bit of cluth judder when pullin away but only if you aint revving much and i get it when i change down from third to second but only if i let clutch off slowly is this normal ??????? Quote
200bhp starlet Posted April 12, 2011 Author Posted April 12, 2011 is it a paddle clutch ?its an organic exedy mate it dont slip or anything other than i said above drives fine apart from those two things ?? Quote
nazzurro19 Posted April 12, 2011 Posted April 12, 2011 mines the same , if i change second to third nicely it judders if i thrash it at high rpm it goes in smooth loli get judder when pulling off too unless i floor it tbh i think its just them type clutches Quote
200bhp starlet Posted April 12, 2011 Author Posted April 12, 2011 mines the same , if i change second to third nicely it judders if i thrash it at high rpm it goes in smooth loli get judder when pulling off too unless i floor it tbh i think its just them type clutchesthats a relief mate thanks first time i have changed a clutch so preety happy now Quote
