Joshua.J Posted March 30, 2011 Posted March 30, 2011 Hi guys, im going to be fitting a FMIC in a couple of days time just wondering if it will hit fuel cut? Car is currently standard with only a bov and de-ristricted. If it will hit fuel cut what am i needing other than FCD? im not up-ing the boost till I've done everything else and got the new turbo and manifold on. Quote
Starbuck Posted March 30, 2011 Posted March 30, 2011 JJ. FCD will be fine to start.I haven't installed mine and don't hit cut with my FMIC. But thats upto you. Quote
Joshua.J Posted March 30, 2011 Author Posted March 30, 2011 I didnt no you didnt have a FCD on yours. Okay guess i will just try it see what happens, do you have a boost controller installed? Quote
Starbuck Posted March 30, 2011 Posted March 30, 2011 I didnt no you didnt have a FCD on yours. Okay guess i will just try it see what happens, do you have a boost controller installed?I do. But i don't have it on yet. The actuator is at 0.65 so thats what i'm running constantly. I wouldn't have thought you'd have a problem running standard boost. Quote
Joshua.J Posted March 30, 2011 Author Posted March 30, 2011 Oh right will have to see what happens then. Cheers again for your help starbuck, im gona ow you so many pints once my car is modded haha. Quote
Starbuck Posted March 30, 2011 Posted March 30, 2011 What you mean 'Once your car is modded'......... start oweing them now. ;) Quote
wull Posted March 30, 2011 Posted March 30, 2011 if you fit a fcd will you not need to sort the fueling out so it isn't running to lean at higher boost levels? Quote
B11G KY Posted March 31, 2011 Posted March 31, 2011 I hit fuel cut back when i had a ct9 just after fitting a rex top mount so id say yea yuo will Quote
