ryan33hks Posted March 30, 2011 Posted March 30, 2011 Yesterday on the way to work my car started to missfire when it was on boost, it was fine when driven off. Then this morning it was misfiring all the time. Ive changed the plugs and thats seems to have solved it. BUT...... 1. I read on here that the plugs i could use were NGK- BKR6EP-11 now when i went to halfords (was desperate) they only had NGK-BKR6E-11 are these still the same plugs? and will they be fine to use? 2. The car still boosts the same but the turbo seems quieter? Normally you can hear it whining alot more through the rev range and hear it spooling quite loudly. Am i being paranoid or could something have changed? Cheers guys Ryan Quote
ryan33hks Posted March 30, 2011 Author Posted March 30, 2011 It may just be me but no i'm not sure it does.. Quote
200bhp starlet Posted March 30, 2011 Posted March 30, 2011 wel, i would of thought that if the plugs you bought were wrong it should still missfire ?? but if it still drives fine and boosts fine then i would think they are ok matey but im no starlet guru like some of the others on here lollewis Quote
ryan33hks Posted March 30, 2011 Author Posted March 30, 2011 Ok thanks mate.Anyone know if the plugs are defo ok to use? and if not could they be the cause of it seeming not to pull as hard? Quote
ryan33hks Posted March 31, 2011 Author Posted March 31, 2011 Bumpneed to know if the plugs are ok please guysAlso the turbo defonately sounds quieter, im wandering if i had a slight boost leak before and since taking the intercooler off and refitting it ive stopped it? Quote
starlet666 Posted March 31, 2011 Posted March 31, 2011 the plugs will be fine mate, the only difference in the BKR6E and the 6EP is that the BKR6EP will have cost u more as it is platinum also, personally i wouldnt use the -11's either, get a set of feeler gauges and gap them down to .8mm instead of 1.1mm ;)i use the BKR7E in mine or sometimes if it is going to be used on the track or given a heap of boost for a few weeks i use R5671A-7 which is a non projected plug pre gapped at .7mm and helps stop the spark being blown out by the high boost i use Quote
ryan33hks Posted March 31, 2011 Author Posted March 31, 2011 Thanks alot mate, put my mind to rest now ;) Quote
