right my turbo is kicking in at between 3800rpm and 4,200rpm it feels stupidly laggy aswell seeing as its a ct9 hybrid
also when driving the boost gauge reads at 0.6vacum and thats when im just cruising at a consant speed
im just getting fed up with having such a laggy car now
is my turbo knackered?
if it was a bost leak surely i wouldnt hit 1bar?
actuator i bought brand new and havnt had it that long, when i remove the actuator the wastegate flap does move freely, it will partly move then stick and needs abit of force to move it the rest of the way to be fully open
If you think about it if the boost is kicking in at 3800rpm instead of 2800rpm then dosnt that ring alarm bells? the higher through the rev range the engine pusses more air through the turbo there for pussing the wasgate open more then it would be at 2800rpm so if you have got a "leak" it will take longer to open the wasgate.
so its most likely my actuator then?
when the turbo was fitted as far as i no, no new gaskets were used so could one be very slightly blowing? as i cant hear anything?
