hi guys,
my waterpump failed friday morning but luckily i had one i had bought of socks on here..
after fitting theres a weird noise coming from near waterpump/cambelt...
and the noise is only there when the car is cold.. as soon as the car starts to warm up the noise disappears?
anyone know what it could be?
made a quick video.. sorry about the lighting, was is an carpark @ work..
http://s1227.photobucket.com/albums/ee428/...t=Video0001.mp4
ishaq
did the pump spin freely before fitting?
the belt might be too tight?
was it the correct pump iirc theres two types.....not sure how much of a difference it make tho
if your really worried about it whip it off and inspect it
the pump spun freely before fitting.. il check the belt..
im not sure about the pump, if it was right one as i thought there was only one type..
sounds like water pump but it cant be, have u run it up to temp sounds dry, like no water to the back of i,t or alternater, or even something on your timing belt did u remove it to do your pump. remove the waterpump belt and start car is it still thr.
