TrisK Posted April 4, 2011 Posted April 4, 2011 my mate is selling a TD04-16The bought a pair to put on his GTO then wrote it off.is this any good for the starlet? does anyone run one of these?what does the 16t mean? thanks Quote
natalie_fuller Posted April 4, 2011 Posted April 4, 2011 my mate is selling a TD04-16The bought a pair to put on his GTO then wrote it off.is this any good for the starlet? does anyone run one of these?what does the 16t mean? thanks16T means it comes on a little later but pulls alot harder towards the top end, this is what i have read up on it Quote
TrisK Posted April 4, 2011 Author Posted April 4, 2011 TD04-16TCompressor:Wheel - 16TInducer Diam (inches) - 1.713Exducer Diam (inches) - 2.205Trim -60Housing - TD04HL-16TTurbine:Wheel - TD04LIncducer Diam (inches) - 1.62Exducer Diam (inches) -1.86Housing TD04L-6cm^2 Quote
natalie_fuller Posted April 4, 2011 Posted April 4, 2011 TD04-16TCompressor:Wheel - 16TInducer Diam (inches) - 1.713Exducer Diam (inches) - 2.205Trim -60Housing - TD04HL-16TTurbine:Wheel - TD04LIncducer Diam (inches) - 1.62Exducer Diam (inches) -1.86Housing TD04L-6cm^2i think there will be a little bit of lag when putting your foot down. but i would think a bigger engine would be needed. maybe your best bet is to Have a TD04L my partner has a TD04L and he says there is a massive difference in size, over a stock CT-9 Quote
TrisK Posted April 4, 2011 Author Posted April 4, 2011 its a td04l wheel? can somebody explain to me the difference btween the td04s and what exactly im looking for Quote
Taggy Posted April 4, 2011 Posted April 4, 2011 If you look up wikidpedia it will tell you about the TD04 range, a bog standard TD04 off a Scoobie WRX is whats in mine, then you get the slightly larger version of the turbo which is what the TD04L is, basically its L for larger compressor.Just remember the bigger the turbo you get the more lag your gonna get, i think the standard CT9 starts to spool at around 2800rpm and the TD04 will be about 3600rpm im toldI think a TD04L would be ideal for your starletits a td04l wheel? can somebody explain to me the difference btween the td04s and what exactly im looking for Quote
