Josh@TunerLifestyle Posted April 6, 2011 Posted April 6, 2011 Basicly the cv joint has gone on my car, i looked over on camskill and ebay and there are loads of types!My cars a 96 glanza with abs , wich one will i need?How hard is it to change?Cheers josh Quote
Gainzy Posted April 6, 2011 Posted April 6, 2011 hi mate try finding a full drive shaft its 50x easier, it should come straight out with a bit of a twist, you will get a bit of oil from gear box just be quick with the exchange. I have a 98v with abs and took one from a 96v, hope this helps! Quote
Josh@TunerLifestyle Posted April 6, 2011 Author Posted April 6, 2011 Cheers dude but what if it dont fit? Quote
Gainzy Posted April 6, 2011 Posted April 6, 2011 which side is it? It should fit if its off the glanza as i say the 96 fitted on mine perfect Quote
Josh@TunerLifestyle Posted April 6, 2011 Author Posted April 6, 2011 Drivers side, il ask around cheers mate Quote
Gainzy Posted April 6, 2011 Posted April 6, 2011 was gunna say av got a full drive shaft and joint for the other side hope you get one though bud!was gunna say av got a full drive shaft and joint for the other side hope you get one though bud!was gunna say av got a full drive shaft and joint for the other side hope you get one though bud!was gunna say av got a full drive shaft and joint for the other side hope you get one though bud!was gunna say av got a full drive shaft and joint for the other side hope you get one though bud!was gunna say av got a full drive shaft and joint for the other side hope you get one though bud! Quote
