nutnut Posted April 10, 2011 Posted April 10, 2011 I have a glanza with a standard turboHave moved the air filter to the front (behind the grille)Front mount intercoolerthe problem i have is the car warms up fine but as soon as i start to drive the temp needle drops down to cold then when i stop the needle moves up again also the car will start to smoke when it warms up on idledont think its the turbo smoking as this is the third one on the car in less then a year.if i put the interior heater on it will bring the temp needle down too which i think is wrongIf the car sits running to hot for long periods the interior heater willl stop working thanks for any help in solving this had this problem for way too long nowthe car is a nightmare to drive in the summer. Quote
string Posted April 10, 2011 Posted April 10, 2011 think liam d had a thread about the cure. as above thermo stat Quote
Steve GT Posted April 10, 2011 Posted April 10, 2011 if you havnt guessed already by the replies abouveId say Thermostat too Quote
nutnut Posted April 10, 2011 Author Posted April 10, 2011 replaced the thermastat Will give it a try & see how it goes. Quote
nutnut Posted April 11, 2011 Author Posted April 11, 2011 it works perfect nowthank you guys for your help. Quote
