Now that my TD04 is on im assuming that the fueling i had rolling roaded for my CT9 at 1 bar is now way out on my RRFPR, does anyone know roughly what psi it should be set to?
standard pressure is 2.4bar, id put it back to that, take off the fcd..
you can run .6/.7 bar on a td04 with standard fuelling as the standard map is very rich.. but its best to get it checked to be 100% sure
I screwed mine to circa 3.2 bar and it fuels well on the wideband but definately get it checked. At 2.4 bar it idles pretty lean but not sure how it is when driving
