lukerobz Posted April 25, 2011 Posted April 25, 2011 hey guys any help would be great as ive tried every thing i could but baisicly i had eye brows on the glanza so i removed them and the sticky like foam tape in a whay that held them on has stayed stuck to the lights ive tried to remove them with brake cleaner, gt3 , wd40, iven tried scrapping them off but that scrachis the lights any body know off anything that would get it to come off chears luke Quote
daz gt turbz Posted April 25, 2011 Posted April 25, 2011 tried a heat gun mate, just steady away though so you dont discolour your headlights. Quote
Dan_SV Posted April 25, 2011 Posted April 25, 2011 tar and glue remover dude. soak a rag in it and soak the tape with the rag, should then be able to rub it off.or maybe warm it with a heat gun, worked when i removed decals of a mates car. Quote
Amjad Posted April 25, 2011 Posted April 25, 2011 Tar/bug remover, spray loads, then heat it up and try scraping it off with your fingernail so as not to damage the lights!Sidestrip glue is really hard and that's how I removed that crap! Quote
lukerobz Posted April 25, 2011 Author Posted April 25, 2011 chears for the quick replys guys i will try a heat gun wer can you get the tar and glue bug remover mate ? on the internet ? Quote
Amjad Posted April 25, 2011 Posted April 25, 2011 I bought some cheapy Turtle Wax stuff from Halfords, does the job! Obviously be careful with the heatgun, I used a hairdryer Quote
Dan_SV Posted April 25, 2011 Posted April 25, 2011 i got my tar and glue from a local motor factors.you could maybe use some paint thinners instead of tar and glue, obviously you would have to be careful with it, don't wanna melt your lenses!!!and as above, go easy with the heat gun Quote
ryan lang Posted April 25, 2011 Posted April 25, 2011 i used t-cut on some old foam sticky early and it took it off a treat, just give it some elbow grease and it should come off, and clean your lights up at the same time Quote
Dan_SV Posted April 25, 2011 Posted April 25, 2011 ^^^^it would probably do the job but you'd have to be so careful not to damage the plastic.think it would be safer to stick to good old fashioned elbow grease Quote
lukerobz Posted April 25, 2011 Author Posted April 25, 2011 chears for the help guys gna nip down halfords and grab sumin when i can gna try a heat gun tmoz Quote
ep91face Posted April 26, 2011 Posted April 26, 2011 old atm cards or credit cards or anything like that with a hair dryer and and wd40 will scrape it off without damaging your headlight Quote
