asbove please, think we have sloved the problem of my clutch ( i hope)
wanted to know whats the easiest way to change it as its in a right tight spot.
any help is appreciated
take off the strut bar and use a 1/4 drive socket and a spanner for the pipe remove the pin that connects the rod to the peddle first very awkward...little advice put a hose on the bleed nipple on the slave open it and pump the fluid from the system as if ya dont it will spill down the bulk head and strip the paint
