sdutton007 Posted February 21, 2007 Posted February 21, 2007 Hi,Does anybody know how to remove the panels next to where the rear passengers fit in an EP82? I want to try fitting speakers into the panels..There dont seem to be any screw holes, and it seems to wrap around just before the front doors so I dont want to just pull it off else I'll probably break someting.Cheers Quote
SiCaln Posted February 21, 2007 Posted February 21, 2007 in my V i had to pull off the panels on the b pillar then the inside frees up, but carries on all the way to the boot, so seats had to come out too Quote
miracle411 Posted February 21, 2007 Posted February 21, 2007 I'm thinking about putting speakers there too mate, let me know how you get on with it, the panels should pop off, might need some convincing though, its plastic so it will bend to a certain degree. Good luck. Quote
lurcho69 Posted February 25, 2007 Posted February 25, 2007 there is one clip at the back top of the panel then it needs to go forward to get off the front door seam. Quote
