Idrees Posted May 3, 2011 Share Posted May 3, 2011 Hi guysI'd like to upgrade from the standard to distributor to coil pack, has anyone on here done this conversion?Any information would be great, ie. what parts I need and whether the conversion is worth the hassle.CheersIdrees Quote Link to post Share on other sites
bucketep91 Posted May 3, 2011 Share Posted May 3, 2011 there is a coil pack on my 4efe on the ep95 dude, im sure that could be made to work. These where also fitted on late spec corrollas 4efe's i think Quote Link to post Share on other sites
Idrees Posted May 3, 2011 Author Share Posted May 3, 2011 Do you fancy a swap for a distributor? I'll hunt the scrap yards for one if someone can confirm what else I need. Quote Link to post Share on other sites
bucketep91 Posted May 3, 2011 Share Posted May 3, 2011 im planning on using it myself if its simple enough. if i dont use it ill let you know. Quote Link to post Share on other sites
_shaun_ Posted May 3, 2011 Share Posted May 3, 2011 guys at ecc done this a few times iirc might be worth droping them a pm Quote Link to post Share on other sites
bucketep91 Posted May 3, 2011 Share Posted May 3, 2011 that was coil on plug conversions using honda parts i think Quote Link to post Share on other sites
_shaun_ Posted May 3, 2011 Share Posted May 3, 2011 ahh so it was just found thread http://www.toyotagtturbo.com/forums/showth...n-Plug-Ignition looks rather smart Quote Link to post Share on other sites
Idrees Posted May 3, 2011 Author Share Posted May 3, 2011 That looks awesome, I wonder how much a set up like that costs! Quote Link to post Share on other sites
_shaun_ Posted May 3, 2011 Share Posted May 3, 2011 yea not sure what management u need to run for it tho think i seen it can be done on an emu . wont be cheap but looks the dogs bollocks Quote Link to post Share on other sites
animal GT Posted May 3, 2011 Share Posted May 3, 2011 you need ecu that can run them for a start!! people use differant type of coils!! loads to chose from,and just wire them up,youl also need to sort your leads out aswel..could have a set coming up for sale soon.wouldnt be cheap doh! Quote Link to post Share on other sites
Idrees Posted May 24, 2011 Author Share Posted May 24, 2011 I've decided to get it mapped on the stock distributor first and see how it runs. Quote Link to post Share on other sites
nastyrash 2003 Posted May 24, 2011 Share Posted May 24, 2011 check out MSD ignition iddy, thy do a piggy back coil on plug system easy to install. and u will lov the throttle respons Quote Link to post Share on other sites
